- Feb 28, 2002
I've been doing tests on O1 to see how well my efforts will perform. I've been making 5-6 blades at once, 3.5-4.25" in length, both hollow and flat grind. The first half dozen I made of 1/8" stock. I've been triple edge quenching in Brownell's quenching oil. They say to use it at romm temeperature, but it heats up about 120 or so after some use. I normalize the whole blade first, let it cool and then do the quenching. First lesson - I ground too thin and all but two warped when quenching. The remaining two (one hollow, one flat) I triple tempered at 400 for 1 hour. I did a quick sharpen - 60 to 400 to a quick pass on the buffing wheel. They would shave hair before and after 60+ cuts. So far-so good. Now the bending. The hollow ground edge cracked at about 60 degrees (no surprise-very thin) and the flat ground blade cracked just as it hit 90 degrees.
I'm well into doing another series in 5/32" leaving a much thicker edge before grinding. Then I will do the same tests. The last series will be with 3/16". Outside of thicker steel and less agressive grinding, the only other varibles I can think of is to temper at 450 for a lower Rockwell and maybe change the quenching medium.
Any ideas on where I should make some changes?I'd like to be able to cut and make the bend test, too. When I'm done with this I may post a page to show the process. All I can say is that I have learned more from all the mistakes of experimenting than anything else so far.
Enough for now - I'm taking the Harley out while I ruminate on this some more....
Bob
http://www.southrivermodelworks.com/page15a.html
Bob
