OC Spray?
SDD
Where do you guys buy your OC or Pepper spray?
I just want to find a good online dealer.
Thanks,
SDD
Moved to gadgets and gear since this has nothing to do with knives.
I'm no expert on pepper spray. I'll make a suggestion anyway. Check out Spitfire. It may not be the hottest spray. It is probably the most easily accessible and intuitive. If the time came, I would probably rather have a .32 in my hand than a .45 on my hip. I look at Spitfire pepper spray the same way. Check out their site—but order it somewhere else. It'll be cheaper for sure. http://www.spitfire.us/about.htm
In my opinion, Fox Labs is the best OC out there. 5.3 million SHUs. Compare that to some other brands and you'll find that many of them are 2 million or even less. It also has a UV dye so police can later identify the suspect even after it's been washed off.
I have the stream (not foam) version with the flip top (not the cop top) for the added security.
Wherever you find the best deal is where I generally buy it from.
fox is the way to go, google "fox OC" and ya will find several places tio buy it.
punch and deftec are also not bad, sabre is supposedly ok too, but fox is the way to go.
I concur. FOX is by far the very best in quality and strength. Expect to burn for at least 50 minutes. I'd highly suggest you get several of FOX's Suedicon wipes for yourselves. Training is highly recommended as there is more to this stuff than pointing and spraying.
Check out Defense Technologies 360. Good stuff that sprays every which way including upside down. I do not recommend foam as I have seen an assailant throw it back at the person deploying.
I've used Def Tech products and it is "okay" but the FOX is insane...it is like Def Tech on steroids x 6! At 6.3 Million Scofield Heat Units no one comes even close. And Ed's (the owner of FOX) quality control is world class.
AND it doesn't come packaged in a Red Fire Extinguisher look-alike dispenser either... just ask the Portland Police Bureau how that works for them.
I've carried Sabre for years and the one time I used it on another human, it worked very well.
