Occasional search problem. Cause? Solutions?
Sometimes, when I try to run a search, all I get is a blank page with "http://www.bladeforums.com/forums/search.php?do=process" as the address. This is really rather annoying, because if I try to do it again, I get the "one search per sixty seconds" page.
Is this a problem with my internet settings (currently using Firefox,) or a Blade Forums glitch? Is there anything I can do to prevent it? Like I said, it doesn't happen all the time, and I haven't been able to notice any pattern to it.
The 60 second timeout occurs because the server thinks you received a valid search result i.e. if you do a search that overloads (common words etc.) you will have to wait another 60 seconds anyway.
you just need to narrow down the parameters as much as possible in advanced search first. I never have any troubles with the advanced search.
Unlike Google, adding terms WIDENS the search.
if you but in BLACK HYENA, the engine searches for anything that contains either BLACK or HYENA.
Yes, BF search engine seems to use a logical OR on search terms, which mean more results. Using less terms, restricting to titles or certain forums only helps quite a bit.
