Did you heat treat in a kiln, forge, or use a torch? If you did it in a forge or with a torch, sounds like you got it too hot (cooked the blade) which to my understanding means, that the elements in the steel started seperating. This usually happens down at the point area, due to it being the thinest part of the whole blade. I guess an easier way to say it would be, you possibly went to far past critical. I've have it happen to me twice and only recently. One was on a very low layer count piece of Damascus and it happened only at the tip, the other time was on a piece of 1080 and the same thing happened. After three draw downs and the finish sanding, the spots wouldn't go away, so I very carefully reground the tip back till the spots were gone (dipping in water the whole time to keep from ruining the temper. Changed the looks of both knives, but they ended up fine. Hope this helps, and I am correct. If not, then I hope someone helps us all and elaborates some more.
