I've got a couple of bulbs from high power lights that a guy who worked for the power company gave me, at the time we were bowhunting aquaintances and he gave them to me to touch up broadhead blades. They worked really well for that purpose, and since then I have used them many times to touch up the edge on many of my hunting knives, they work on a wide variety of steels. They are about 1/4"n diameter and about 3 1/2" long, I don't know what kind of lights they came out of, just that he said they were 'high power'.
What's a 'thermowell' ?
I've got a couple of bulbs from high power lights that a guy who worked for the power company gave me....I don't know what kind of lights they came out of, just that he said they were 'high power'.
It's usually a hollow white ceramic tube. It gets inserted into heated manufacturing equipment with temperature measuring sensors inserted into the tube. When the sensor fails, it is easily replaced. They work just like a 'crock stick' for honing knives as they are made of the same material. Not sure what the grit rating would be though.
....what you need is a 1000watt bulb, the element in those bulbs are about 10" long......
Is it good grade of ceramic?Those tubes from HPS (high pressure sodium) bulbs are a material called quartz-ceramic and are extremely hard, you'll most likely never wear them out, this varies but I have seem them from as course as ~2k grit equivalent all the way to ~5k.
