I was initially curious about the French Douk-Douk folders when I read about them here, and then I was impressed with what tough, simple, inexpensive utility knives they are after I got a couple of them. Now my Douk (the original 4-inch, now called the medium size) rides in my pocket at all times, along with my ever present SAK Farmer. But after reading where some people compared the Douks to the German Mercators I finally had to see one of these for myself. I ordered another Douk along with a Mercator "cat knife" from www.GarrettWade.com, and last night they arrived on the BBT. (BBT means big brown truck. Think UPS.)
The design of these two knives is similar, so I have to wonder which came first. The Douks hit the market in 1927 I've read, but I've also read that the Mercators were often used by German troops in WW2, and then some were brought home by returning GIs after the war. Obviously, both have been around for many decades. Anybody know which one came first? Anybody know of any other knives using this folded sheet steel handle design?
A few differences I've noticed between these two knives:
(1) The Douk is carbon steel, but the Mercator uses a stainless blade.
(2) Although the Douk has a very strong spring, so far it is easier to open.
(3) The Douk does not have a locking blade, nor does it need one!
(4) The Mercator has a locking blade plus a very strong spring.
(5) The Mercator is hard to close because of the location of the release.
(6) The Douk uses a "Turkish" clip blade, the Mercator a spear point.
A few similarities I've noticed:
(1) Both use a very sturdy folded sheet steel handle with good rivets.
(2) Both have a strong, useful shackle at the rear end of the handle.
(3) Both are very nearly the same size, within an eighth of an inch OA.
(4) Both have carefully ground (wedge ground) blades.
(5) Both are very sturdy, very simple, relatively inexpensive knives.
(6) Both have a good design that has definitely stood the test of time.
The Mercator I just received is one of the newer production ones. It does not have the famous cat logo on the handle, but it appears to be virtually identical otherwise. The sticker on the plastic bag says "Made in Western Germany." That's not West Germany, though. It's all one Germany again as of several years ago. The blade right at the handle is stamped "Mercator" on one side, with "Germany" and "Solingen" on the other side. The blade has a nail mark, and on that side is etched a small otter logo with "Otter" printed under it. Also it has "Messer," "Solingen," and "Handmade in Germany" on that same side of the blade.
Now, how about some more input on these or similar knives?
