Food grade mineral oil is better than vegetable oils. They will dry out and gum up the works. They can also go rancid. For on just the blades, fine assuming they don't go all that long between use, cleaning and oiling again. I do use Canola on my cast iron cookware and the blackstone. Regular use fine, long term storage no go.
For BOTH sharpening on oilstones and for protecting a non-stainless blade from rust, any food-safe (USP grade) mineral oil will be the best solution, and inexpensive too. A very inexpensive, USP-grade mineral oil is sold as 'intestinal lubricant' (a laxative) at grocery stores in the pharmacy section.Recommendations on a oil for rust protection/sharpening on a stone...and which is also safe to use on knives dedicated to food prep. Will a light coat of cooking oil suffice (ie olive oil/canola). Thanks in advance
Kitchen stores sell butcher block oil which is the mineral oil I have and use. You can also find mineral oil at many pharmacies.When I read Bushcraft 101, and good old Dave Canterbury said that he oiled his carbon steel knives with olive oil, I had all of the issues that you raised. I agree with you (except that thing that you once said about tequilas under $30). So, pardon my dumbness, but could you give an example of an appropriate mineral oil?
Thanks.![]()
