Oil Stains In White Smooth Bone
What have you tried? And do you know what kind of oil it is?
I would start with soap/water.
Then I would probably try rubbing alcohol.
If that doesn't work, I would try some sort softer scrubby pad with soap and water and then maybe try rubbing alcohol or some other mild de greaser agent.
And if that doesn't work, I would try buffing it out with a piece of leather or really high grit sand paper.
After that, you only option is sanding it out or living with it as far as I am aware...
Good luck!
Another option - if you can’t remove the stain (too deep, etc.) - perhaps you could add oil to the rest of the handle and stain it to match. It’ll be more protected from moisture that way too. :)
Blast it with brake parts cleaner and immediately wipe with a paper towel.
Ugh. Try the above, but once oil sets in bone it likes to stay there, and attracts dirt. You may need to oil the whole handle to get a uniform look.
If the oil used is a pure food-grade mineral oil, which is completely colorless and clear, it should clean up well with a liquid dish soap and warm or hot water. Other lubricating oils might not be completely colorless and might alter the look of clean, white material, rendering it yellowish or green. I realized a long time ago, this is how food-grade mineral oil easily cleans up from my hands, sharpening stones/hones and anything else. The main caveat being, if the oil is blackened by dirt or steel swarf, it'll be difficult sometimes to get that dark & dirty stuff carried in the oil out of porous material, even if the oil itself is largely removed from the material. If any dark, gritty particulate stuff gets embedded in the bone, it's very difficult to remove it completely without doing something more extreme, like sanding down to clean bone (I'd avoid that, most of the time).
So, with all that being said, the first thing I'd do is wash the knife in warm water with liquid dish soap, using a brush (old toothbrush) to do any scrubbing. Then rinse it all out with hot water, which evaporates quickly, making complete drying easier. And making sure the pivots are clean before oiling would minimize any staining caused by dirty oil seeping from the pivots when the oil is applied.
