- May 11, 2018
I've recently learned how to sharpen with a whet rock and use a old Norton crystolon combination stone and have ran out of oil. could gun oil work on the stone or would it damage and break down the stone?
if i use the stone dry, would i have to clean it after each use? If I use it with oil will i have to clean it frequently?
That simply isn't true.Bottom line, a stone that's been used with oil is a commitment, to keep using it with oil. They can be cleaned of most old oil by 'boiling' or other means; but it's usually not worth that amount of trouble.
Worth repeating. Some good advice there, your stone will work with water if you have put oil on it before. Don’t make it too complicated....Yes, you can use soapy water , even if you used oil on it before.
The worst thing that happens if you use water is you get to do
Only the surface needs to be cleaned,
and that is as simple as old toothbrush and soap and water,
or a run through the dishwashing machine (soapy hot water sprays).
If that doesn't clean the stone, scrape the surface with a hacksaw/nail....as shown in video above...to reconditon recut revive resurface your sharpening stone
Then use oil or use soapy water ... as long as it floats on top it'll work better than dry.
I totally agree.If you want less mess, just use water. You get the benefit of less clogging than dry...
