Does anybody know if the solvents in common oil/varnish finishes, like the Watco Teak Oil I tried out yesterday, can dissolve cured resin from stabilized wood?
I used this teak oil on stabilized wood I got off ebay which I'm betting is cactus juice stabilized. I had sanded to 3000 grit and, wiped and blew off the sawdust but not with tack cloth or compressed air. After I flooded the handle with teak oil for 45 minutes, when I wiped it off, a bunch of small surface imperfections and voids appeared. It's stabilized burl so it actually looks really cool this way, but I'm wondering if these surface imperfections were there to begin with or the teak oil dissolves resin? I've used Watco Tung oil finish on stabilized burl wood before without this happening, although not from the same stabilized wood seller.
Also, I noticed that the oil/varnish after application then wiping tends to open up grain in bocote which is naturally oily. Am I just not cleaning up the surface enough after sanding or is something happening with the oil/varnish stripping oils or resin from wood?
