Why would you oil micarta? Just for looks?
This makes no sense. Just use the knife and the oils from your hands will naturally make the micarta look "oiled".
Some info from a knife maker who uses both:I have even a more fundamental question since I have never owned nor seen a micarta handled knife; what is the attraction to it say over g10? Toughness, looks, weight, or what?
I think you're right on track with your "treatment" plan for micarta. If you use a micarta handled knife for a lot of food prep or sanitary activities, you'd like to have control of the stability of the oils that penetrate and seal the porous material. Your trick with linseed oil puts you in control of what "adds character" to your micarta. Not only that, but most natural lipids (animal and vegetable fats) will behave differently over a fairly narrow range of temperatures. What feels dry and stable under cold conditions may feel slick and oily under hot conditions. Linseed oil is a good choice, as would be a high grade mineral oil as they have a fairly flat temperature viscosity response over the typical service temperatures.I have done it. I give em a wipe down with boiled linseed oil when I get them.
Micarta darkens over time as it absorbs oils from your hands, grease from whatever you are cooking over he fire etc... for the most part it's nonporous. But the fuzzy ends do absorb, so I get a jump on it by loading them with BLO. It means there's less opportunity for other crap to soak in.
I also find it makes them easier to clean, and gives a more even darkening.
I'm no scientist, so I don't know if what I'm doing is effective at all but until I know otherwise, it makes me feel better.
