OK enlighten me. Oiling the handles is done just to be bring the colors out? I assume the micarta just absorbs it and doesn't become slippery.
With my "frenchglish language" :
This Tiger Hide micarta is made from canvas + some kind of epoxy.
"Canvas Micarta is the toughest of the three grades. It surpasses linen Micarta by a large margin for strength and durability. Canvas also offers the best overall texture for slip resistance." http://web.archive.org/web/20050211010009/www.bussecombat.com/handles/
Personally, even if it's practical, I don't like the feeling of this grippy texture in my hand. So, to polish this texture I treat canvas micarta like wood :
1. I polish the micarta with some superfine woolsteel (lightly if you want to keep the Busse machined patterns).
2. I put some water on the micarta : the result will be to lift the micarta grain again.
3. I polish again the lifted micarta fibers always with some superfine woolsteel.
4. I repeat this operation (water + superfine woolsteel) until the lifted fibers are gone even if the micarta is wet.
5. I let the micarta to dry.
6. Some people prefer G10, especialy on hunting knives, because micarta soaks up grease, sweat, blood. Effectively the very surface of canvas and linen micarta may absorb a very small amount of fluids in the exposed fibers; so I put some multiple layers of boiled linseed oil on the micarta to seal it and to reveal the color, and I polish with woolsteel if necessary again. Boiled linseed oil will darken the micarta, but it will make it water-resistant. Apply the oil, wait 15 minutes, then wipe it all off (or as much as will come off) with a dry cloth. If you don't it will dry and will be the hell to remove…
"Linseed oil is a "drying oil" as it can polymerize into a solid form. The reaction is exothermic, and rags soaked in it can ignite spontaneously. Due to its polymer-like properties linseed oil is used on its own or blended with other oils, resins and solvents as an impregnator and varnish in wood finishing, as a pigment binder in oil paints, as a plasticizer and hardener in putty and in the manufacture of linoleum. The use of linseed oil has declined over the past several decades with the increased use of alkyd resins, which are similar but partially synthetic materials that resist yellowing." Source : http://en.wikipedia.org/wiki/Linseed_oil
Macro from Lunde pic :
