Will try the Sharpie trick, these knives are 27 years old and never been sharpened besides a few swipes on the Henckels sharpening rod, so they've never been sharpened!
That's what I was looing for, thanks David! Are the diamond and CBN rods made by Spyderco?That's a pretty strong clue. The vast majority of factory edges on kitchen knives are usually pretty 'thick' (wide edge angle, and/or literally thick steel immediately behind the edge). Using just the rod likely has rounded that thick(ish) edge off even more. Reprofiling down to 30° inclusive (15°/side) or lower will make a huge improvement, and will also make further maintenance of the edge a lot easier, down the road. You might consider the diamond or CBN rods for the Sharpmaker, for that task, which will make it much easier.
David
Yes, Spyderco makes Diamond and CBN rods for the Sharpmaker.That's what I was looing for, thanks David! Are the diamond and CBN rods made by Spyderco?
David
Using the Medium rods?
Right. Using the SM's 30° slots, if you do not see any Sharpie being removed except at the very edge then the bevel is less than 15°dps.
Reapply the Sharpie and test again with the Medium rods in the 30° slots.
And do you still feel any chips and nicks? Also try running a sharp edge of a plastic BIC pen down the edge to detect chips and nicks.
If little Sharpie is removed and you feel no chips or nicks, how well does it cut? Try phonebook paper?
If you still feel chips and nicks, you might try more pressure on the Medium rods.
If still feel chips and/or still won't slice, you may indeed need something more coarse like the Diamond or CBN rods.
To reprofile it to >15°dps, you will also need something more coarse.
