OK, I ordered a mtech mt 151 Trail Master knockoff and guess what?
Along with the edge and grind angle not being in line with the handle and a bowed blade the guard was loose. I called mtech and told them about it and they said they would send a return label for an exchange. Well, I haven't received or heard anything back plus even if I did and returned it I doubt the replacement would be any better since the canted bevel, bent blade seems to be the norm. So figuring I'm stuck with it I took it out back for some chopping. It did great going going through 1" - 2" cedar limbs, anything bigger and I felt stupid standing there hacking, life's too short for that. But the guard became more loose as in clacking when I hit something. Since I'm stuck with this is there a way to tighten the guard without removing the Kraton handle which btw I like. Other than squeezing some J-B weld under it all around I can't think of anything. If I tack a weld on it the Kraton would melt and if I removed and put the Kraton back on I doubt it would stay on permanently. If I did take them off I'd replace with Micarta. A lot of work on a cheap, bent piece of steel.
