If what I think you're saying is what you mean, then I may know how to stop it.
When at the end of a stroke on the Sharpmaker, do not let the tip come off of it. Keep the tip on and stop the stroke, the begin again at the top.
As for the other types, it must be similar situation. With the lansky, the tip could be too far away from the mounting point, messing up the angle and dulling the edge. With free handed stones, make sure the tip doesn't swipe off the edge, just like the Sharpmaker. Also, freehand, you really have to watch the angles because even as you get comfortable with the stone, it changes shape a bit as it wears.
With any of these, you could try the marker solution.
Before you sharpen, use a marker of some sort to color the edge of the knife. When sharpening at the right angle, it will naturally rub off the marker. If you see it sharpening unevenly, or leaving marker on, you can adjust and not have the rounded tip problem in the first place. Then, you can get a feel for what is going on.
Good luck with this, and remember, patience is a virtue.
