Thank you. Dohhh. I just looked at the box, and it does say both Insingo and Inkosi. Mystery solved. Now, just gotta get her smoothed out. Right now, it's almost impossible to open one handed.It is an Inkosi with an Insingo blade. If it is new it might need to be broken in a little and it will loosen up. The pivot screw can be loosened on an Inkosi to help with opening.
The nice thing about the Inkosi is if you do need washers then CRK can send them to you without the knife going back to them to be fit like a Sebenza.
I expect the knife needs broken in an little and does not have a pinched washer.
That is a very nice knife!
chrisreeve.com
Opening a CRK is all about technique. You gotta find the sweet spot to hold and the sweet angle to push.
Yeah, apparently the previous owner had this sucker cranked down pretty tight. I had to loosen the pivot several turns, to get it to open one handed. Still not the easiest to open, but at least I can do it.The Sebenza has a pivot bushing, so you can tighten down the pivot screw all the way and get the same action every time. The Inkosi does not. Try loosening the pivot a tiny bit at a time, and you should be able to find a sweet spot of no side play AND one handed functionality. The pivot of the two different models cannot be treated the same.
