i have been using my Dominator on and off for the past 6 months. it is part of my EDC rotation and sits in my right hand front pants pocket when i'm at work. my usual EDC is a MT Scarab, but for some whimsical reason, i decided to take the Dominator the other night a couple of weeks ago.
my Dominator has held up quite well and i have not had to touch up the blade. the lock up was solid and it is one of the most comfortable folding knives i have. while i'm changing for work, i slip in the Dominator in my pocket for the shift. well, towards the end of my shift, my mates and i stumble upon a rather large illegal operation in a house which needs to be torn down.
i became very annoyed with a pair of clipping shears that were dull and didn't work, so i switched over to the Dominator. the Dominator's blade sliced through electrical cable wire with ease... with no visible damage. went through at lease a dozen electrical cords. even cut some "hanging" wire that wasn't very thick. i was working in a very damp and wet environment but i wasn't worried as the S30V and the titanium would be fine. i then put the Dominator to work cutting down the "vegetation" in the basement and the blade held up great considering that the "vegetation" has a reputation of dulling blades quickly.
then it was onto the heavy rubber tubes that connected to some equipment... this is where the Dominator had a bit of a problem. it wasn't the cutting ability, it went through the rubber hoses very effectively, but needed some effort to push through. there was some twisting involved and the lock did not fail at any point. after about the 4 hose, the Dominator felt a bit funny... the lock seemed to "click" and the handle/frame felt ever so slightly wobbley. on closer inspection, i noticed the locking engagement of the frame locking surface "slipping" on the blade locking surface. i tried drying the knife off and flipping the knife to see if i could lock the knife without the lock slipping... no go... the lock kept moving. i then put the knife back into my pocket, a little discomforted, and moved the last peice of equipment out of the basement.
having completed 9 hours of overtime, i went home and slept the next day away. when i woke up, i tested the Dominator again and it was still slipping. it was totally dry at this point, so i couldn't blame it on moisture. i took out my TORX drivers and stripped the Dominator right down. i cleaned every part and took particular attention to the locking surfaces. there was a bit of (for a lack of a better decription) slimy material on the blade and blade's locking surface. nothing seemed damaged, at least to my amature eyes. i then placed a a bit of pressure on the frame lock and bent it "inward". now i don't think i could have bent the frame lock very effectively as titanium is pretty sturdy stuff and i would think it takes on a pretty stiff memory... but i could be wrong. i then reassembled my Dominator, and low and behold, it locked up tight! just as tight as new! happy happy joy joy!
i have tested the lock and it does not slip anymore, enough for me to be satisfied that it will not fail. the locking surface on the blade is not finished smoothly (but not finished rough though) and i suspect as i twisted the Dominator through the rubber hoses, the slimy material worked itself into the grooves. then again, i could be totally wrong about this and the slight pressure on the frame lock fixed the problem... could be that it just needed to be cleaned too.
well, that was long winded... sorry about that. i'll just end it by saying i still carry the Dominator as an EDC and it still has my confidence.
Jon
