Cliff Stamp said:
Where were yours? The one I had was about 0.040", which is fairly heavy duty. The problem with the Beckers was the tolerances, it tended to vary a lot, especially on the larger blades like the Patrol Machete.
-Cliff
I don't have it with me, but from memory it ran about ~.030-.035 behind the edge, the edge bevel itself was really acute though. I did not measure it (sent it off for a custom handle before I used it) but it was under 15 degrees per side, as I was going to use the Spyderco Sharpmaker to add a microbevel (20), and comparing the edge to the rods I noticed that I could actually cut in a bevel using the 15 degree rods with plenty of clearance from the shoulder.
I bought it a while back from Mike Dye at New Graham, excellent service. Once I got it, I remember why I detest the Becker grip configuration, as I had used the Campanion and BK7. Again, decent knives with a handle that was not suited for my hand at all.
As for its scope of work, with the stock edge, I would feel comfortable working with most any green wood, limbing most sticks except the real hard, dry stuff, and I would not trust it to hold up to ring knots or the like.
I would probably use it on soft metals, copper wire, thin aluminum cans, and such and most plastics except thick PVC.
In contrast, the Ranger RD9 I would use for the heavist of work, it has a much thicker grind (I will measure it tonight, I'll guess it is ~.050-.065 at least behind the edge) and I imagine the 5160 is a good bit tougher and the small shop heat treat superior to the large batch heat treat that Camlilus uses.
Given that there is not a great price difference between the knives, I would readily choose the RD9, choosing a stock edge for really heavy work or requesting a thinner edge for most tasks. IN fact, with the additional costs of the custom handle (more than the cost of the knife), the Becker will actually cost me more than the RD9 and have a more limited scope of work.
