- Jun 3, 2019
A few days ago I was profiling a series of blades, and like a good "frugal" belt user I used several previously used 60 grit ceramic belts to do that work (they had been used for beveling). the first belt did a good job, but it seemed to me that the steel continued to get hotter and hotter at a quicker rate (I did dip in water to keep temps down). Eventually I saw small areas where the steel was adopting oxide colors and getting REALLY hot .... so I swapped out that belt for a second "previously used" belt. The difference in heat generation was immediately clear (the second used belt did not heat the metal clearly as much). However, the first belt, though heating the metal, definitely continued to cut the metal.
So the question is - how worn is "too" worn before you just throw a belt out??? (with the understanding that they get cycled down to less heat-sensitive uses - like never use a significantly worn belt for final thinning of a bevel.
(as an aside, I am slowing getting more courage to run the grinder at faster and faster speeds. In this case I was running at 100 (meaning 100Hz???) - and oh man - can those belts really chew through steel!!!!! I would most definitely not want my fingers to contact say a 30 grit belt running at high speed!!!!!!)
