How about some better pictures of that first one, is the white side of it very soft and fine?Are they still usable? The left one for example is noticeable damaged on the second picture.
Will try, thanks!Should still be usable, yes. They will probably need the surface reconditioned as they appear to be clogged with hardened oil. If simply running them through a flattening process (I recommend loose silicon carbide grit on a flat piece of glass or tile) fails to remove the hardened oil glazing, boiling them in water can often lift that film from the surface, followed by scrubbing with a stiff bristled brush. If that doesn't work, you can soak them in mineral spirits to dissolve it.
HeavyHanded , there definitely is a chance, since I am from Belgium. Will keep you guys updated. Any recommended videos for the flattening process?
That is a fantastic find. A great finishing stone that can be used a lot of different ways.
