Old Hickory Butcher Knife mod??
I just ordered a couple of these from Ebay and am looking for some mod ideas. I don't have a grinder, but I do have a dremel.
http://www.ambientweather.com/mook7030.html
Is there anything good I can pull off with these? I just love the simplicity and am looking to make a custom outdoors knife out of it. Any ideas would be greatly appreciated. Thanks
I doubt that it will ever be a good chopper, because the blade is probably relatively thin. But it should make a good knife for cutting things.
If you really wanted to get alot out of it, you could send the knife to Paul Bos to have it re-heat treated. I doubt that the heat treat is optimal, though it may be good.
I think I would replace the handle with some Micarta, G10, or Carbon Fiber (Be careful, these materials produce a very fine dust when you sand it, not good for your health. Wearing a respirator is proper procedure.) You can get these synthetic handle materials from www.knifekits.com . Barring replacing the handle, I might make some grooves in it to make it more grippy. Once you get the knife if you don't like anything about the ergonomics, you can just grind/sand it to where you want it. Some things you could consider adding are: finger grooves, a finger choil, or jimping. You could also sand down the handle and then stain/finish it however you want to.
Without a bench grinder changing the blade shape more that a little bit would take awhile. I suppose you could add serrations on the blade (or spine) or saw teeth on the spine, but I personally would stay away from these options. Mostly personal taste, but I also think that it would be difficult to grind a saw that works well without some experience.
I used to grind the tips off my v-nox butcher knives to look like that. Its an exellent shape to cut meat with.
The geometry is good for cutting, but the heat treat leaves a lot to be desired. I have several, and they are *way* too soft to hold an edge for a good length of time. If you could find someone to re-heat treat them, I would definitely make that a part of the process.
I used my Dremel to make a blade shape similar to a Kbar. These are good knives that are too cheap to not buy some and try different things. I am going to try my hand at filework on the spine next.
Have fun.
It also might be worth getting one to practice heat treating, yourself. Re-grind, HT (go to non-magnetic), quench, then re-pollish/finish. If possible, be sure to post pics!
Good luck!
Jim L.
