t1mpani
Platinum Member
- Jun 6, 2002
Picked this up recently--decent condition, unused but neglected. The stag scales had shrunken and pulled away from each other, also pulling away from the ends of the pins a bit. The blade was about as sharp as could be expected on such a low saber grind---meaning not.
If I'd pressed really hard and sawn back and forth it probably would have eventually broken skin. Where most of the blade was ground too thick, the tip was much too thin and had already developed a good bend in it.
Now if I'd really wanted to do this right it would have been a complete re-handling, but I just decided to see what could be done with the original setup.
Naturally, my initial overall shot of the knife came out as a corrupted file, but here's the two-parter to start:
Stab from the left...
One way to finish off a swedge that's not cooperating, I suppose...
Oil your stag, please...
Gee, do you think it's watertight?
Okay, first things first. Devcon 2 ton clear isn't the strongest epoxy in the world but it's clear and so great for filling. Little playing around with white and yellow dyes to try and match the stag. Of course it ends up a uniform color so it will never fool anybody, but it looks pretty good from two feet away. Filled in and drying...
After a day, it's dry enough to mess with (I don't like to sand it before 48 hours at least) so take care of reprofiling: The whole upsweep on the tip was just clumsy--lots of graduating straight lines instead of a smooth curve. Then of course there's the aforementioned swedge foible and the skinny tip. So, a little file, sander and stone work (and a lot of pretzels) later, and we're reshaped, convexed and sitting pretty (although not polished yet of course):
continued below...
continued below...
