Old Tools...and their stories
killgar
I like tools. I'm not a "tool fanatic", I don't need to own every tool that exists, but I appreciate tools, what can be done with them, and for most of my life I made my living with tools. These days, other than working on my bikes, most of my tooling involves hobbies.
I always enjoy threads about tools, and I came up with this idea. So if you have an old tool, one with a story, please share, I'll certainly enjoy reading about it.
Here are some of mine.
1. I grew up in a house in the 1970's, and there was an old swing set in the back yard. This thing was HUGE. It had a slide with a crows nest, two individual swings, and a 4 person carriage swing. It was a heavy duty set, all steel construction (except the swing seats), and the main support structure was made of large diameter (3.5") heavy steel pipe, all bolted together (made in the 60's).
I was the youngest child, and I got years of enjoyment out of that set, it was my "pirate ship", but once I grew out of it, dad decided it had to go (got in the way of mowing the grass). Problem was, the bolts were all rusted together, there was no way to unbolt it. And dad wasn't the type to pay someone to dismantle it and haul it to the dump, especially when he had me around, I was around 11 or 12 years old.
So one day dad brought home a new hacksaw and a bunch of blades, handed them to me, and instructed me to cut up that HUGE swing set into small enough pieces that we could load them into the family station wagon and take them to the dump. That's it, no guidance whatsoever.
Over the course of an entire summer I cut that behemoth down into car-sized pieces. No small task. I would go on to use that same saw for all manner of tasks and projects throughout my youth, I particularly remember using it to cut ninja stars out of circular saw blades. I still have that saw, and I use it regularly. If you've ever seen my switchblades, it was this saw that I used to do all the cutting of parts. Unfortunately as a child I didn't always appreciate tools, hence the rust. I left it outside overnight more than a few times.
Good ole' Blue (the handle is actually a darker blue than it appears).
2. When I was a kid I had a lot of chores. One of them was to carry the trash cans out to the curb the night before trash day. But we didn't have wheels on trash cans back then, and for an 11 year old, those cans could be HEAVY. So to spare me a broken back, one night dad brought home a dolly. But it wasn't assembled, it was in a box, in pieces. He gives me the box and tells me to put it together.
Assembling the dolly was a simple enough task, but there was a problem- the wheels, which had heavy duty steel hubs, were supposed to have plastic bushings in the center for the axel to pass through, but one wheel was missing the bushing. There was no way that wheel was going to work, the hole was too big. I go to my dad, expecting that he would take the dolly back, but instead he just says to me "Figure it out".
"What the hell" I think to myself, what am I supposed to do? Then I remembered that we had an old set of wheels from an ancient lawn mower that had long since gone to the dump. And as luck would have it, the rear mower wheels were about the same diameter as the dolly wheels, and the center hole was the perfect size for the dolly's axel. So I decided to use the mower wheels instead.
Not so fast, there was another problem. The hubs of the mower wheels were too thick, like two steel bowls welded together. There wasn't enough room on the axel to accommodate both wheels and still install the cotter pins through the end of the axel. I decided to use the good dolly wheel, and one mower wheel. But still not enough room, just barely. I needed to narrow the hub of the mower wheel.
So I grabbed a ballpeen hammer, and hammered the hub inward until it was thin enough to fit on the axle. And so I had a functional dolly to take out the trash.
That dolly served me well into my teens. After my dad passed a few years back I found the dolly, it had seen better days. The handle was covered in rust, and the rubber wheels were all cracked. I needed something to wheel around my 80 pound 12" disc sander, and I thought the dolly, with a little modding, would be perfect. So I sanded off the rust, painted it, replaced the wheels with a pair from Harbor Freight (perfect fit), added a plywood base, and once again, after all those decades, it saves my back and serves me well.
I also use it to haul my solid aluminum motorcycle wheels, with tires, to a nearby shop for tire changes. And that alone makes it worth it's weight in silver.
3. No real story behind this one. It's just my very first power tool (Ram Tools, out of Chicago). You know a power drill is old when it has an all-metal housing. I guess at some point people decided that an all-metal housing was dangerous, I heard people were getting electrocuted from metal shaving getting into the drills and causing shorts, but I don' know if that's true or an urban legend. I still use mine. It was a big step up from the eggbeater drill I started with, although I thought that eggbeater was pretty awesome.
Thanks dad, for making tools a part of my life. And thanks for making me figure things out for myself, I'm a better person because of it. :)
avoiding dating self, was given these when roughly 10 y.o. by an old timer that i looked up to the same as a grandfather and who also happened to have introduced me to firearms...
they sit on kitchen table and are used for occassional work on folders & paracord items.
I spent an entire summer out in that yard, cutting that behemoth down into car-sized pieces. No small task. I would go on to use that same saw for all manner of tasks and projects throughout my youth, I particularly remember using it to cut ninja stars out of circular saw blades. I still have that saw, and I use it regularly. If you've ever seen my switchblades, it was this saw that I used to do all the cutting of parts. Unfortunately as a child I didn't always appreciate tools, hence the rust. I left it outside overnight more than a few times.
I have that exact same drill.
Picked it up af a thrift store a couple years ago for I think $2.99.
No chuck key though.
$2.99? Damn. Does it work?
I've still got the chuck key. It used to be attached to the cord but I removed it. Standard small key, I've used different ones.
I used to have the paperwork and metal box the drill came in, but the paper was heavily moth-eaten, and I preferred to keep the drill in a tool box with anther drill, so I ditched that stuff.
The brushes need replacing but yes it does work.
Great thread!
I have a South Bend heavy 10 toolroom lathe. It was "FREE". Free is in parentheses because nothing is ever free. One day, a coworker says to me that he's got a lather he doesn't want. Got it himself from a co-worker years ago. Now, this is an older guy, and an old school machinist, so I know the thing isn't a pile of crap. At the same time, the doesn't seem to know much about it. It languishes in his basement for a couple years, and I finally decide to tackle the project. It has to come up out of his basement through a bulkhead, and get into my basement, same setup. So, me and a buddy go over there, and we take this thing apart into enough pieces where we can haul it up and get it in the truck. I don't know what it weighs, but it's VERY heavy. The bed is 3 1/2'. We get it in the truck, and on the way home, I stop at the dump and go over the truck scale. It's about 800 pounds. So, down my bulkhead it goes, and it's pretty grungy, and lo and behold, there are rebuild parts for it. Oiling wicks, grease and such, along with a very nice book on how to operate it and take it apart. So I order all that, and take it apart, and clean it, replace those things, and put it back together. Now, the lathe has seen better days, bed is worn, and I also find out that Grizzly industrial currently owns the SB rights, and has all of the old paperwork. For $25, you can get a copy of the original paperwork, from 1943 as it turns out. It tells you all of the accessories it came with, along with who was the distributor, and the original owner. Super cool. Another guy gave me a VFD to run it on, since the motor was a 3 phase. That doesn't last long before the VFD lets out the magic smoke, and I decide to double the HP, and switch to single phase at the same time. I get that done, and upgrade the tooling a little, and I've been using it ever since. Having a lathe is a great thing, even a tired one like this. And this beast has NO plastic on it! Well, except for the handle of the tool post that I added. So, I've got probably $600 into it, but I could sell it for more than that.
Ahh, old iron....
More recently, I decided I needed (wanted) a surface grinder. All the used ones on FB marketplace are big, heavy, expensive, beat, or all of those. If you wait, you'll get what you want, though. One day I come across and ad for a Delta-Milwaukee ToolMaker grinder. Smaller, built in the 30's. I go see it, and it's been nicely cared for, and gone through by it's current owner. Turns out this guy is a machinist, and specializes in grinding stuff, so he went through it and re ground all of the sliding surfaces. Very nice, and he only wants $450. Deal, done. Same deal, took it apart, out of his basement, up a bulkhead, and back down mine. But all I had to do was put it back together. It looks very art deco, and again, no plastic.
Not old iron, but still no plastic...
Why would I want a Wiley E Coyote blasting box? Well, who wouldn't? I love fireworks, and I have a State Display Operator's license, so this kinda goes with that. I look for years, and all I find is blasting boxes on E-Bay going for $5-800. Yeah, no. At some point, I decide to build an honest replica myself, but I couldn't find the generator part to save my soul. This project languishes for years. One day, I find one in FB marketplace. It's about 3 hours away, and the guy wants $450, a very good price. "Does it work, and will you ship it?" He didn't know, didn't want to find out, and no, he wouldn't ship it. 8 months goes by, and I decide that it looks good enough in his photos that it's probably worth what he's asking, even if it doesn't work. So we go get it. As soon as I saw it, I KNEW it would work. Looks almost unused, and he's got the original box it came in, though the box is pretty beat up. I get it home, and yup, it works all right...
Do you have any idea how much fun it is using one of those things?
Wish I lived closer, I’d be happy to lend a hand . That old fence tool has rode many a mile in several saddlebags.:)
Care to share the story of that tool? I think the story is the most interesting part of a tool.
Are you it's original owner? Has it been in your family and used to fix fences for generations? Do you know from where it was purchased (catalog. little old general store. etc.)? Stuff like that.
