The Sarge's Blades aren't marked, but older HI Blades were marked the same way as now, but without the UB.
Older ones had a single kami mark on left side of ricasso and no initials; right side of ricasso was blank. Initials were added later, sometimes in Arabic and sometimes Devangari; then marks moved to right side of ricasso.
I don't believe I've ever seen any Arabic-alphabet letters on a khukuri, H.I. or not. Devanagari and Roman/English, but not Arabic.
When I first started here with the HI Forum and khuks the early Shop 1 HI Khukuri's were marked only with the HI logo at the bend in Devanagari and had what is known as a "scrolled buttcap."
It was a two piece affair with a "scrolled" skirt soldered onto the buttcap proper making it look like a very thick piece of brass. While very pretty they were a royal pain in the arse because they couldn't be modified without messing up their appearance.
When Pala and Uncle Bill decided to strike out on their own and Shop 2, the forerunner of BirGhorka, came into being there was a time of transition and while not remembering all that happened or the order it happened in I do recall bits and pieces, so while I will put the bits and pieces down the way I remember them remember that what I write below is in some general but no particular order....
It was decided that the khuks would be serial numbered and although they were indeed numbered, in numerical order the best I can recall, I don't think there was any records kept as to when the numbering started or stopped.
The early Shop 2 khuks weren't as nicely fitted and finished as the Shop 1 khuks were but they were adequate and good honest to God khuks!:thumbup:
Then for a short while because of import requirements of having the place of origin placed on all imported products all of the HI Khuks were stamped with, "Made in Nepal" but it wasn't long until Uncle Bill found or figured out all that was needed was a piece of tape or such imprinted with "Made in Nepal" on the khuks so the ugly stamping was done away with.
Y'all need to remember what I said above about me remembering bits and pieces as some of these instances overlapped once in a while I'm sure, like the numbering and "Made in Nepal" stampings I'm pretty sure....![]()
Somewhere along about then it was decided that we would like to have the kamis mark their own khuks with a stamp that would always remain their very own. Like so many things in a culture we're not accustomed to that happened so so. The Nepali Flag mark over time became the mark for two different kamis, some of the other guys will recall who started out with it, methinks it was Durba but I'm not at all sure.
Then since the individual markings didn't work out it was decided that the kamis should use their initials along with them so that was started.
Somewhere along about then I think the four direction sun mark was added to insure we were getting a real HI khukuri. From there methinks everything is recent enough to search out if need be and the markings have evolved into what we have now.
So there you have it the best I can recall, I'll email Norm with the url to this thread as he keeps excellent records and may have everything on a spreadsheet in the correct order.![]()
Return of the J.D. said:I don't believe I've ever seen any Arabic-alphabet letters on a khukuri, H.I. or not. Devanagari and Roman/English, but not Arabic.
