olight m20 flashlight
Just got my , olight m20s . I wanted to swap the black button, for the glow in the dark button, that came extra. I couldn't figure it out!:confused:
I do not know anything about Olight, but I'm sure someone over on candlepowerforums could help you out. All about flashlights!
There should be a couple of indentations in the inside of the tailcap, to the sides of the spring. Use forceps or something similar to unscrew it and swap the rubber boot.
I did the same thing on my M20. The "guts" in the cap screw out, then you can remove the button and replace it. I used a small pair of needle nose pliers to do it.
Thanks for the advice, ..... took a minute, plyers slippded and I dinged the inside a little.... , but now I can find it in the dark, if I drop it , or the power goes out. Seems like they could of made it more user friendly. Or at least put it in the manual. :D
