Olight S2R - Another Great EDC option from Olight
A-MAC
Olight S2R, another great EDC option from Olight. Like others in the recent line it comes in minimalist packaging making it easy to store if you keep packaging like me. Also like those in the recent line, the UI is the same. In fact, this light is almost the same as the S1R that was recently released except that it takes an 18650 cell (included) instead of a 16340, this makes the light longer overall but the same diameter. This also makes the run times longer and the Turbo a little brighter. This light has the same floody beam we are becoming used to from Olight and as I said earlier the same UI. One push of the button for on, pressing and holding while on cycles through the modes and a single push while on turns it off. Double click while on or off gives you access to turbo, triple click activates strobe, press and hold the button from off for moonlight mode. It also has an electronic lock out, if the button is pressed while locked the light will flash moonlight mode for a second to indicate it's locked. Magnetic tail cap doubles as the charging port and you can use a 3 or 9 minute timer function. Included in the package are a charge cord, 18650 Li Ion battery, instructions, lanyard and felt bag.
Olight S1R vs. S2R
Low mode (12 lumens) @ 2 yards
Medium mode (120 lumens) @ 5 yards
Medium across the yard to show flood and beam profile
High mode (500 lumens) @ 10 yards
High mode (500 lumens) @ 20 yards
Turbo mode (1020 lumens) @ 20 yards
Turbo mode across the yard to show flood
