Review Olight SMINI Thunder Grey Stainless
A-MAC
This light was provided to me by FastTech at a discount in exchange for an objective review.
For Olight fans this light will see familiar but really is something different. Familiar in the sense that the features, function, fit, finish and operation are the same as most other Olight flashlights. Different because Olight normally produces black coated aluminum lights with the special editions coming in titanium, brass and copper. It's not often that they produce a stainless steel light. This particular light has a very cool thunder grey coating. I am a fan of plain knives and lights, with my favorite finish being bead blasted titanium or simple black coated aluminum. The thunder grey coating is plain enough for me to keep this one around and the blue bezel and button accents give it a little flash with out being flashy (pun intended).
Like most of Olights recent releases this light is very compact with a side switch being one of Olights most notable features. The TIR optic produces Olights almost signature beam pattern, not too floody or spotty. It's great for up close and distance work. The pocket clip is solid but also easily removable and allows for quick attachment to the brim of a hat for an impromptu head lamp when both hands are needed. The pocket clip fits in machined grooves in the body which keeps it from spinning and while it does clip into the pocket optic up/out it rides very low. Lanyards can also be attached to the picket clip in two places. The SMINI doesn't have a magnetic tail cap, my guess is that it was eliminated to help save space. A single CR123, RCR123 or 16340 runs this tiny powerhouse.
Like other models a single switch press turns on the light memorized to the last mode used. Pressing and holding the switch while on changes modes (high, medium, low). From off pressing and holding the switch puts you in moonlight mode. Pressing and holding form off and through moonlight mode locks the light preventing accidental activation. While locked pressing the switch yields a quick flash in moonlight to let you know its locked. Simply press and hold until moonlight mode is activated to unlock the light. From off a quick double tap puts you immediately in high mode, which ramps down from 550 lumens after 1.5 minutes to 300 lumens to keep the light from overheating. A triple click from off activates strobe mode. Instant access to just about any mode from off and an electronic lock is what makes this light one of my new favorites.
As you can see from the pictures the packaging is simple. A padded box holds everything together. The owners manual rides in the flaps in the top of the box keeping it out of the way and it comes with an Olight CR123, non rechargable battery. Unlike most other lights the negative end of the battery goes toward the led/optic and the threads on the tail cap are buttery smooth. The stainless body adds a little heft to the light but in my opinion it's a good heft. Overall this is a great light to carry to the office as it would dissappear in just about any outfit but I wouldn't be afraid to carry it to the jobsite either. I do both daily and haven't had any problems so far. Olight really hit it out of the park with this one and the SMINI series in general. The stainless version runs a few dollars less than the TI or CU making it a great value.
image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg
Thank you for doing all of that! A lot of times people just give shots of the product and a few words.
My issue with this light is it looks so fat.
Short and stubby for sure compared to other lights but not compared to the battery. Not much bigger than the battery. Pictured with a Streamlight Microstream (aaa) and an Eagtac D25A Ti 2014 (aa).
I love the design and colors.
I EDC my microstream because it is on/off operation only for concealed carry, moonlight won't help much or powering through settings.
I can see this for my EDC bag but I already have a Streamlight Protac 1L for that.
I may pick one up eventually.
Is this one rechargeable?
I agree, the super simple Microstream operation and momentary on is appealing.
Not directly through the light like the Olight "R" series of lights. It takes 16340 and RCR123 rechargeable cells though.
I like CR123A lights, very powerful and decent runtime. Buying the batteries in bulk on Azon Streamlight or Surefire and you get good shelf life and really save money on batteries since I use AA or AAA Lithium Energizers as it is.
It's just hard to argue with an AAA on size and batteries can be found anywhere in a pinch. That's why I have a few of each type of light. :)
You are preaching to the choir my friend. I carry an Eagtac D25A Ti everyday, either the 2014, 2015 or 2017 version. It's definetly my favorite light and it takes AAs. I've been slowly moving to rechargeable cells for everything then in a bind if I need a bettery I can grab one from anywhere.
I usually wear shorts on the weekends and CR123 lights disappear into the bottom of my pockets, can't beat the output.
