On the edge
I was curious. How do you guys test for sharpness. Pushcut telephone book paper, newsprint, skin, hair. I like to cut dangling fine hairs but since I cut my hair this has become exceedingly dangerous. Now I am into cutting short fine hairs. I wonder what I will lose first. my fingers or my hair. Anyone have a better method?
Push-cutting thin layers of skin off the end of my left thumb... Can't do it too often though so I leave this for the final test after it pops hairs nicely.
Also, push-cutting a piece of 1/4" thick expanded plastic foam I have. Not sure what plastic it is (not polystyrene or polyurethane) but it just deforms if the blade isn't really sharp.
Edit:
I missed taking the tops off my chest hairs. My arm hairs are a bit fine really, although I managed it with my Barkie after a lot of stropping.
Rick.
Push cut lightly against my fingertips. :eek:
I also use the blade against fingernail tests too. (rest at an angle, and slide across feeling for smoothness)
I cut my rubber chicken (that doesn't sound right).
I do the chop lots of wood and shave hair afterwords. For serious sharpness I pass the blade along my arm just above the skin with out touching. If the hairs jump out of the way I'm good. :)
I sharpen it with sandpaper, strop it, then just beat the heck out of it on some wood!
Need.........better...........stropping.................skillz..............
I chop cinder blocks to test the sharpness :thumbup: then shave my back.
I typically test on regular college rule notebook paper, cardboard and hardwood.
In no particular order:
-slice various thicknesses of paper
-see how easily it cuts small pieces of skin off tip of thumb
-run down finger nail and see how easily it grabs and/or shaves the nail
-shaving arm hair
I have found for instance that trying to slice that paper that Campmor catalogs is made of (thinner than phone book paper I think) seems to be the ultimate paper test...gotta be pretty sharp.
Lots of self mutilation involved here if you didn't notice ;-)
I find that sharpening is lots of fun but it's easy to get compulsive about it. I have to admit that my ultimate test is rather dangerous. I hold a fine hair between my thumb and index finger. I then cut it in half. On two occassions I have cut the tip off of my fingers. But I find that the hair test is always fun. When the knife is as sharp as I like it will grab any hair no matter how short and fine and shear thru it even when I swing the knife slowly. I would like to find an alternate method that is just as illustrative but a little less bloody.
my true test of sharpness is to cut free hanging beaver hair. it is very fine, almost like fur if you will. now a days it's getting harder to find a good supply of this, in the seventies it was way more plentiful.
if you don't have access to a good beav pelt then i guess muskrat fur or frog hairs would do in a pinch. :thumbup:
I have three tests. Unfortunately, I am a very poor sharpener so I have never gotten past the second test. But maybe that day will come...
Test 1: Shave paper. Not a push cut, just a regular slice.
Test 2: Arm shaving.
Test 3: I chop the air a few times and sniff for ozone. Alternately, if there is a storm outside, I go and try to chop a lightning bolt in half.
If a knife passes all three tests, it is officially sharp :thumbup:
You are correct Skunk
They were way more plentiful back in the good old days
Too Right Skunk
WHere are the days of yesteryear
Gillette,
man's best friend:thumbup: :thumbup:
I do have a badger hair shaving brush, but that cost me way to much money to go and chop up with knife.
That dang AIDS virus changed everything, huh?
MY last attempt at using Beaver pelt got me slapped into next week, particularly since there had been a recent waxing.
