- Jan 26, 2002
This issue makes a re-appearance periodically, as in one of the current threads about those "other" khuks (and advocates).
Many of the early HI khuks had buttcaps of such appearance, often decorated, but they are hollow,cup-like, soldered constructions, not a solid plate. Almost like the bolsters, or a capped ferrule.
Some of the old-timers probably can add more, but the short version is, that they were often constructed of thinner stock than currently used, and due to imperfect fit/finish or handle material shrinkage were potential irritants, especially on shorter handles. Plus, they severly limited the amount of handle re-profiling that could be done, especially if constructed of thinner stock.
Bill apparently went through quite a hassle to get the current type of buttcap consistently produced, but he was convinced that it needed to be done to make a better product, even if ascethics suffered.
From an archived thread:
"Kami has instituted a couple of changes in shop 2. One is the buttcap. The traditional buttcap is the biggest source of complaint and of failure. It is too sharp because of the eye shape, it likes to come loose because it is hard to fit with the boiling Himalayan epoxy, and it is basically just too flimsy to be of much use. Even the scrolled two piece HI buttcap made at shop 1 although not flimsy is subject to digging into the hand and loosening. So shop 2 khukuris will have a buttcap like the Gangaola khukuri. A somewhat thick brass plate with a sort of Z shaped keeper. This cap is anchored in two places to the handle and is held in place by the mushroomed tang. It will not dig into the hand and will not loosen -- a major improvement. And, it is traditional but harks back to an older tradition."
http://www.bladeforums.com/forums/showthread.php?t=125294&highlight=scrolled+buttcap
A search for "scrolled buttcap" will turn up others.
Can't say that that is the way those "other" khuks are constructed, but it seems most likely. And, among their selection, some khuks have the plate-like cap, some lack a full buttcap, and some have what appears to be the soldered-construction buttcap.
Hmmm, sorta like HI, except HI decided that the soldered construction buttcap wasn't worth the problems.
