- Dec 12, 2001
This post has been troubling me ever since I have read it:
This post awoke in me the need to find out once and for all: Why (really) does CRK harden their 1-piece line (A2 steel) to 55-57 RC?
I have heard that this is to allow them to be "field sharpenable" in a pinch (an overrated option IMHO). I own a project II. I like it no love it but I would like it to hold an edge longer (who wouldnt want this from any knife?). Lately, I have been seriously considering sending it someplace to have it custom hardened to RC-60. The thread I have quoted above, along with several others, is what led me to this idea. If I decide to do this, I will then send my knife back to CRK to be re-coated (and yes, I know that a custom heat treat will void my warranty). I would obviously love to just have CRK do the heat-treat, but the last time I contacted them to ask if they would do such a thing, I was told that they would not harden the knives any more than RC55-57 because it would make them too brittle... Unfortunately, I have to admit; that I just don't agree such is the case. Bear in mind however, I only believe this (perhaps) out of ignorance all my heat-treating knowledge is based on what I have read AND the reason I have not yet sent my P2 anywhere is because I have a nagging worry that hardening it to RC-60 may in fact not be a good idea afterall (Its hard to not heed the wisdom of the CRK staff). Yet the more I think about this...I think that even a slightly more brittle, but harder 5/16"(?) thick blade of A2 might fit my needs better that the alternative...
Comments??? I would especially like to get some hard & fast comments from some of the CRK folks J Thanks in advance to all
Originally posted by rdangerer
Most steels tend to get tougher as you lower the hardness, as a general rule, but there are distinct exceptions, like A2 and D2.
I just thought I'd point out that A2 is a bit weird... it has a toughness "hump"... data from a Crucible Handbook on A2:
Temper@....Hardness Rc...Toughness Charpy C (ft-lbs)
400F............61................31
500F............60................41
600F............59................37
700F............58................33
800F............58................31
900F............58................29
1000F...........57................41
I.e., if CRK takes A2 down to Rc55-57, they do make the knife somewhat easier to sharpen in the field (overrated benefit IMHO), they give up some edge holding/abrasion resistance for sure, but probably get back to a localized toughness peak at Rc57 or less.
To Cliff's point, a selected few steels at their toughness peaks vs. HRC (at least per the data set in Crucible's handbook in a hardness range that might be used for knife blades). Order is in relative terms of "wear resistance, adhesive", highest wear at top:
Steel....Tufness(ft-lb).....HRC......Adhesive Wear Resistance
M4...........32.................62.........20-25
M2...........20.................62.........8-10
3V...........40.................62.........8
3V...........50.................60.........7
3V...........85.................58.........6
D2...........23.................60.........3-4
A2...........41.................60.........2-3
A6...........67.................55
L6...........68.................56-58
O1...........32.................55-57
S5...........138.................58-60
S5...........156.................56-57
S7........... 85.................59
S7...........125.................57.........1
S7...........190.................47
Hardness helps with edge retention, prevents "rolling" of an edge, but abrasive and adhesive wear resistance is only fairly correlated with hardness.
Nothing turns out to be terribly simple in terms of relationships between hardness, wear resistance, and toughness.
