INFO: it is spec'd at 50-54 RC, so they are going for toughness rather than edge-holding. Given that it is intended to get you out of a crashed aircraft, that is understandable.
Brace yourself for "alternatives."
Any info. or experience with this knife?
How about alternative suggestions?
Also, hollow handle, storage fixed blades, the good, bad, and ugly!
The Gerber LMF-II ASEK is the replacement for the old Ontario, IMHO a much better knife.How about alternative suggestions?
If you want a knife made for the same purpose, the Gerber LMF II is designed mostly with that same purpose. They even have an ASEK version with the proper leg straps and a strap cutter attached.
Hollow handle knifes are usually a blade bolted to the handle, thus only as strong as the bolt. The Chris Reeve Project is a solid piece of metal, but not made anymore. The Schrade Extreme Survival knife (1st version - not the current lineup) is 1 piece and designed based on the CRP (with Reeve' approval - not a knock off stolen design). I have one, and it's a decent blade I use and would rely on. The new Boker Plus Aparro is a bolt together model that is designed by Martin knives and is supposed to be as strong as a full tang knife.
