Sure I bought Ontario knives and discovered problems in the sheath designs. Unfortunately, I could not locate suitable, replacement sheaths or modifications. The alternatives appeared to be 1. ship me your knife and I will custom make a sheath for you; or, 2. buy a $150 grommet snap tool and install your own with a desired snap closure.
Came up with a range of solutions to replacing non-functional velcro straps on an Ontario sheath. Or, if there was a snap closure, but you wrapped the scales and now the original snap closure was too tights.
The best alternative is to replace with a snap on closure and a piece of webbing material, but who has $150 for the proper tool?
I have used 550 paracord with paracord stops, but ohhhhh.... It works. However, you might fumble a bit on opening and closing the restraint.
So then I tried metal buckles with webbing, but too bulky.
Now I am going to use a piece of 3/4 inch webbing with a plastic buckle that has a built in emergency whistle in the buckle. From Strapworks. Of course, I will have to sew the material onto the buckle and then the unit to the existing Ontario sheath. A bit bulky. However, the restraining buckle arrangement will be flexible to allow a wrap of paracord on the scales if later desired.
I spent hours researching if some entrepreneur had come up with a replacement sheath that would be as functional as the Ontario sheaths. However, there weren't even any off-the-shelf sheaths that I could find.
