- May 14, 2010
Hi all,
Long time reader, first time poster.
I've recently bought an Ontario RAT 1 and noticed it was starting to rust. No big deal, just put some WD-40 on it right?
Well, after opening it and spraying it then putting it back together, it seems the liner lock is pushing hard against the blade which causes the cutting edge to be pushed against the steel frame when I am closing it. It creates a scissors type effect which will damage the blade.
I thought it might be the screws are too tight, so I tried loosening them but that just made things worse. Then I thought it might be the ball bearing not sitting on the small track, but upon testing if it snaps closed when close to completely closed, it appears to snap normally (which tells me that the blade is sitting on the track properly).
There were a few small plastic washers that covered the copper/bronze? washers surrounding the hinge which I had removed earlier, but then I put them back into the opposite side of the liner lock to try and force the blade back into centre, but that made no difference.
I'm stuck for ideas on how to fix this.
Anyone got any?
Edit: Oops, this thread probably should go in Traditional Folders and Fixed Blades
Anyone got any?
