I have been experimenting a bit with opening my large Sebenza. The problem I had initially is that at the start of an open cycle there is a jerk/pause in the action. I felt I should be able to open the knife without any pause or jerkiness; it should be one smooth motion from closed to open. What I have found works for me is the following:
1. Place tip of thumb on side of lug with the thumb pad touching the frame
2. Push outward on the lug.
3. As you push outward turn the thumb down onto the blade (with the lug as a pivot). The objective is to have the thumb pad press firmly against the blade to provide additional leverage. Use the lug as well as the thumb pad friction to further open the blade. This is the critical move that eliminates that irksome initial pause.
4. As you open the knife the thumb pad should naturaly come off the blade.
Edit - As Dave mentions below be careful of the knife edge. Make sure your thumb pad lifts off (or at least stays away from knife edge) as the knife continues to open.
Regrettably I do not have a camera to post a video of it.
What advice/technique can you offer for achieving a consistent and smooth opening action without any pauses?
Cheers.
Cheers.
