Grinder should be fine on -10 but I m not sure about user14F is -10C. Since he is in Canada, probably what he was referring to.
Running a cold machine is just like running a cold car/truck. Let it warm up a bit. If the shop has a heater you fire up when working, fire it up an hour before starting the grinder. When you start the grinder, let it run slow for a few minutes to allow the grease to warm up, bearings to warm up, and rubber wheels to soften up a bit. After that it should be fine to grind on.
Well if you think that belt kicks up surprising amount of wind ...you should see what my 17 inch contact wheel do ............... hurricane 4 categorythe moving belt kicks up a surprising amount of wind and that wind chill is uncomfortable.
I've tried those rubber type "mechanic's" gloves and they help, but give you better feel, without problems of getting wet.
