Nope. The N°6 diameter is too large and the height would put the pivot pin channel too high on the N°5 collar. As far as I can tell, there's no simple way to make a locking N°5 without actually sanding down the handle and cutting down the blade of a N°6 (I'm assuming this is what you're aiming for). It's a good project, though.Does anyone know if the locking safety ring from the No.6 (the smallest opinel with a ring) can be transferred to the smaller No.5 successfully?
Yah, it COULD be done. But methinks I'd rather give a swift rap to the peening on the pivot of the N°5 and just make it stiffer to close.A guy with a file and a pair of pliers may be able to crimp the lock ring over a dowel or even the No.5 bolster, after trimming it for length and opening up the slot. I’m not too hopeful, though. The raised rib in the lock ring will make it difficult to bend cleanly.
Why do you want to do that anyway? The six is the perfect size. ;-{>
Zieg
Zieg
The other problem is going to be nub that Opinel has added for some insane reason to the inside of the locking ring. This nub fits in a groove milled inotthe inner bolster of the knife and keeps the ring from coming off too easy.
Opinel has changed the designed enough to make it harder to fiddle with it. I can't begin to guess why they totally messed up a good design, but they've really done it.
Not only is the inner nub a problem, but the locking ring is now capable of being turned in only one direction. There is no longer two slanting edges on the top of the locking ring, but one and not goes in a counter intuitive way for a right handed person.
I only know this because I recently went fix up an Opinel for the grandson of a friends birthday and once I got into it and saw how much O[pinel had messed with it, I went and bought the boy a Victorinox recruit for the same amount of dough.
I'm pretty disgusted by the new changes in the Opinels, and no longer will be messing with them. Too bad.
There are at least a couple of ways to respond to these developments:
1. Nothing cool ever lasts.
2. It doesn’t sound like anything that couldn’t be addressed with a file or a Dremel. But,
3. why should you have to?
Some people say that Opinel went wrong when they introduced the Virobloc in 1955. I disagree, but I think the notch that holds the blade closed, while not a bad idea, may have and some unintended consequences. Before the closing notch, it was not too difficult to remove the lock ring if you wanted to, but it took a conscious effort, not just to get the ring past the pivot pin, but to be prepared either to catch it or to hunt for it if it decided to take flight.
With the closing notch, it became possible to launch the Virobloc inadvertently, simply by pulling too hard on the blade to open it against a closed ring. It took a hefty pull against a relatively loose ring, but it could be done. So, perhaps to address an issue created by their own “improvement”, Opinel has added superfluous complication to a setup that was wonderfully simple and elegant.
I haven’t encountered one of the new lockrings yet, but I may try one, just to see how difficult it really is to undo the new arrangement.
Sounds like a lot of work for a $15 knife bought new.![]()
