I agree with bruce CPM3V, four times as tough as A2 and will hold an edge much better, This steel is so tough I would hardin it to 59-60 even for a chopper!
I would use a interupeted oil quench or a double quench with frozen quench plates, this steel demands that you get the temp. down FAST. Thats the way I due it and I am totaly impressed with its performance. For hunting knifes I set the angle to 12- 15 deg at about 62 Rc, For a chopper at 60 rc I would try 15-18 deg. I bet you will be impressed. Keep in mine 3v only has about 7% chrome but also has 4%vandium which makes it stain resistant, It will rust if you don't take care of it, but not near as bad as carbon steels.
Recommended Heat Treatment: For the best combination of toughness and wear resistance, austenitize at 1950°F (1065°C), hold 30-45 minutes, and quench. Temper 3 times at 1000°F (540°C).
Aim hardness: HRC 58-60 Higher austenitizing
temperatures can be used to obtain higher hardness, at a
slight decrease in impact resistance. The lower austenitizing
temperatures provide the best impact toughness.
http://www.crucibleservice.com/datash/ds3Vv5b.pdf?CFID=856627&CFTOKEN=51031604
Leon Pugh
