Hi,
I'm an owner of a small classic Sebenza.
I'd like to hear people's take on tweaking the lock bar bend. You folks prabably know what I mean by this, but for those who don't know, it's overbending the lock bar "out" or to the left to relieve the lock strength. The excessive lock bend to the right, for sure, makes the lock stronger. On the other hand, it causes marring between the lock face and the blade tang, hence the soar thumb and fast wearing of your knife, and also makes the action less than smooth.
I've seen posts where a number of senior members passionately discourage the tweaking, however. In fact, just to prevent overbending, a device called lock stop has been invented. On the other hand, upon some more search, I've come across posts where several reputable members and a couple of revered framelock expert makers "hinting" that when the bending out is done with discretion and care, it may help the action of your Sebenza, or all framelock folders in general which suffer from stiffness.
Here is a summary of a post I read, which I wholeheartedly agree with:
Despite the popular belief that smoothening the washers/pivot makes the action smoother, the most of the friction comes from the detent ball pressing down on the blade tang. To test this, push on the lock bar hard enough so the detent ball is not touching the blade tang. You'll find that then the blade is suddenly very free to rotate, and will fall only with gravitational force. All those times you spent on polishing the washers and lubing gone to nothing! Normal Sebenzas have so consistently smooth pivots from the factory, yes, thanks the bushing system, that they have not needed the polishing after all.
The only way to relieve the friction is to somehow lubricate the detent ball, which certainly won't stay for long on such a small area, or to ever slightly reduce the very strong bend to the right that CRK puts into the lock bar. The less rightward "spring" pressure the lockbar has, the less friction you'll feel in the action. But if you don't know what youre doing, you could easily reduce the tension too much, which may rid the self-correcting ability of the lock and eventually develop a blade play. The good news is, though if you went too far, you can fix it by bending it back to the right until you find the sweet spot between tight lockup and smooth action.
I, myself, am certainly not under impression that to bend the bar back and forth multiple times is OK. Titanium is a flexible metal, however over stretching back and forth like that most definitely will reduce its durability, as a paperclip bent 10 times would snap. However, I think CRK might be producing Sebenzas with just a tad too strong lock bars, which is definitely a plus on the safety and the reliability side, but maybe too much for the casual users like me who enjoys opening and closing the knife occasionally.
So upon close inspection and some experimentation, I tweaked the lock strength just right for my taste, no more "way too sticky" lock for me, and I'm a happy one. Well, thanks for reading, and please give your feedbacks!
Q
Q
