Recommendation? Opinions on first knife
Just starting to learn about the different types of knives, from steel type to blade form factor. Looking for some opinions from you seasoned owners. I've got my eye on a few.
From Spyderco:
From Cold Steel:
Cold Steel 58PC Code 4 Clip Point Folding Knife 3.5" S35VN
From Zero Tolerance:
Zero Tolerance Model 0350 Assisted Flipper Knife 3.25" S30V
Hi! Welcome to the addiction, I mean club! It's always best to start with a bit more information.. like budget, what it's primary use will be, and are there any must-haves or deal-breakers?
Of what you listed, I've owned a zt350 and while I did like the knife... I'd pick a few others ahead of it .. but again... More details will help in suggesting alternatives.
Welcome! Bladeforums is a great resource for all knife related information, however if you ask for advice on a purchasing decision, you will get a lot of different recommendations. This is a journey about find what YOU like and need in a tool. I'd say the best way to start is to check out some of these recommendation/personal interest blades and try handling them a good knife shop. If you don't live near any good stores, the pass around forums on here offer the same purpose. The worst case, you could order some from amazon and if you don't like them return them in under 30 days. Get a feel for what you like and enjoy the process. Next you get to have the enjoyment of using the one(s) you choose. P.S. those options you mentioned are both good blades. I'd recommend you the zt 0562 will offer you a similar type of blade but without speedsafe (shop around in the exchange and find a used one for cheaper). Cheers!
Like myowngod said, we could use a little more info. The more detailed the info the better opinion we can give. That being said, you cant really go wrong with spyderco. I personally like the paramilitary 2 in S35VN or if you want to go a little smaller the paramilitary 3.
...From Cold Steel:
Cold Steel 58PC Code 4 Clip Point Folding Knife 3.5" S35VN...
Not a big fan of Cold Steel personally but their Code 4 line is something that even I would be willing to consider. Especially the drop point version.
If I may suggest:
Buck 110/112
Spyderco Delica/Endura
CRKT M16 series
Benchmade Griptilian
Spyderco Para 3/PM2
These five knives give you some of the most common lock types on the market. Might as well test them out also.
The 0350 has been my first over $40 knife and while I have sold it and moved into other styles of knives, I can only recommend it
it is a very good beater knife
I liked the high of the handle but it was a bit too short for my use
i finally moved to the PM2 which has more length in the handle and it was fine for me
the liner lock on the 0350 is good
I problem with that
if you don’t like the assisted opening you can just removed the tension bar, but I never had to complain about mine
the pocket clip is not deep carry but that makes sense for the kind of use this knife is intended for
i don’t have the code 4 but I have a pro lite tanto. It is a cheap entry into cold steel and it is a good blade for the price
i think the code 4 should be even better
IMO take the one that looks better for you, use it and make your own experience
my first knife was a 0350, I some more ZT, some BM before moving into spyderco, Hinderer, TRM, CRK and Koenig...
some alternatives to the 0350
Spyderco PM2
BM super freek
ZT0562
The 0350 was on my list for a quite a while. So was a DPx HEST. Between the two, I think the ZT is probably the better knife. Certainly a little more practical.
Then I started using my Griptilian more and more. I came to the conclusion that it was all the folding knife I probably would ever need. If it wasn’t enough, I needed a fixed blade.
Of the two you listed you can't go wrong. Just starting out I would probably go for the Code 4. It's not USA made like the ZT but it is half the price for practically the same steel. The lock is stronger than a framelock and it is more beginner friendly than an assisted opening flipper. You can spend the extra money on an M390 Kershaw Link or Dividend and you'll have a USA made assisted knife in M390 steel and a Tri-Ad lock folder in S35vn for the same price you'd be in a single ZT 0350.
Spyderco Delica best all around EDC
From your list I like the 0350 better but I didn't like the one I had at all.
The handle was too short and the blade was overly chunky.
Spyderco PM2 is another good one
The ZT 0350 is one of the less expensive ZT's and the one I first looked at in a store to decide if I wanted to try a ZT. There was lots of talk here about how great they are and I wanted to see for myself. I ended up getting the 0770 Carbon Fiber which is also assisted (AO). It was my first and only ZT. I have nothing against ZT's and I think they make a good knife. I like the knife better than the 0350 because it's slimmer. It rides in my pocket comfortably, but I believe it costs a bit more. I don't think you can go wrong with a ZT if the knife is comfortable to carry. I suggest you look at one in a store before you buy and make a judgement about AO's. Things moved to flippers from AO's and most people seem to like them better overall.
I have been moving to more manual knives and the most recent modern knife was the Benchmade Mini Presidio II which I like quite a lot. It is still a one hand opener with Benchmade's most excellent axis lock. I generally carry a small Vic SAK most of the time to give you perspective and the modern is a second knife if I choose to carry one. I have been carrying a small fixed blade lately as a second knife most of the time. But if I grab a second folder now, it's usually the Mini Presidio II.
Spyderco makes very good knives overall. The Native is one of my favorites and about the same size you are looking at. For a less expensive Spydie, the Delica is a great knife and very easy to carry.
The ZT350 is my work knife of choice, most days. Solid every day knife for sure.
Primary Use?
Budget?
Any restrictions on what you can carry at/on the job?
Hard to go wrong with a SAK such as the Recruit (has a pen blade) or Cadet (has a finger nail file in place of the pen blade) or Farmer or Pioneer.
From Spyderco:
From Cold Steel:
I would honestly not buy new at all, look at the selling section and get a bargain deal. If you have to go new, the Doug ritter mentioned above is possibly one of the best deals going, I love mine.
Im biased but don’t like assisted knives. Opening is great but needing two hands to close is a deal breaker.
Word of warning, be ready to spend a lot of money. When I first started I thought “I’ll maybe get two”. .....now I’m at well over 100 bought, sold, traded, rebought, etc.
I have both of the knives listed.
Instead of the Code 4, I'd suggest either the CS Ultimate Hunter or Recon 1. The Code 4 scales are metal, thin, and slick. I don't like them. I prefer a thicker handle + G10 like the Ultimate Hunter or Recon 1.
The 350 was my first (and only) ZT. Great knife.
Either way, you can't go wrong. I know CS knives aren't for everyone but they make a great knife for the money imo.
Sorry for the delay. I had several more listed in the original post, not sure why a Mod removed the Spydercos. Those were Manix2, Para3, Native 5, Chaparral.
I have no real purpose for them (at the moment). Budget under $150. For reference my hand size is 5 1/2" x 7 1/2"
EDIT Typo: measurement 3 1/2" (breadth) x 7 1/2" (tip of middle finger) -- Average size hand.
I have a manix 2XL, I really like it. I also really like the cold steel broken skull. You won't go wrong with anything on your list though!
