Opinions welcome! Best AUS8 field sharpener?
I'm just curious; I use SOG's Seal Team Elite and the Seal Pup Elite. Both have AUS8 steel and I'm looking for some help on finding myself the best field sharpening device I can find that is not rediculously expensive or needs a ten page instruction manual to use. I have a couple in mind but am interested in outside opinions. Any constructive help would be appreciated.
Have you looked at the Work Sharp guided field sharpening kit? About $35 I think. Looks like a good field/portable system. There have been some posts here about it in the past. I think they are members of the forum.
http://www.worksharptools.com/
Blessings,
Omar
Have you considered learning free-hand sharpening? For under 20$ you can have a 2x6" Norton combination coarse/ fine India stone delivered to your door. This sharpens my AUS-8 steels easily and gives a nice shaving edge. DM
DMT Aligner clamp ($12) and a sheet of wet/dry sandpaper. Maybe two different grit sheets if you are feeling rich. Being a multi-millionair, I usually bring three sheets, but that really just showing off. Total carry weight... about 2-3 oz.
Stitchawl
DMT Diafolds work great for AUS-8 steel (and any others). In the field I carry a red/green combo. Freehand sharpening is not difficult to master (even I can do it:D).
I do like my Spyderco profile set when on the go but they are discontinued, though you can still find one online i guess.
I also love the suede pouch as a ghetto strop which i rolled with a pin to remove some of the nap then soaked it in a solution of white compound and wd40.
The only issue with this kit is common with any ceramic sharpeners, they dont remove a whole lot of stock so you wont bring back to life a badly nicked edge.
Best? Well that is a matter of opinion... However, a cheap Smiths Diamond Sharpener really cant be beat in my opinion... I think its called the DCS4 or something... you can pick them up just about anywhere. You can really sharpen about anything on it in the field or at home. I have used bifold diamond sharpeners but the Smiths seems to take to cake at less that a 20 dollar bill. Light, portable, versatile, cheap, and readily available, it will sharpen your aus8 perfectly.
... or your axe, machete, folder, fixed blade, garden shears, nail clippers, yada yada yada yada....
AUS-8 is pretty easy to get along with. If you prefer freehand sharpening, I think the recommendation for a simple Norton stone (either India or Crystolon) is a good one. If you think an angle-guided system would help you out, the suggestion of the DMT Aligner clamp & wet/dry sandpaper is good (not very pricey, either). Any diamond hone would also work quickly, and a DMT Fine (600 mesh/25 micron) would fill the bill easily. The DMT 'credit card' hones are very, very handy in that capacity, and the Dia-Fold hones would also be a good option (Coarse/Fine would be my first choice, among those).
Ceramic hones like the Sharpmaker, etc. are very handy for light touch-ups, but will be very slow & tedious if some major re-bevelling or edge repair is needed. The diamond hones and the Norton stones are more aggressive, and better suited for such jobs. Same is true with the wet/dry sandpaper, in coarser grits (220-400).
A simple & firm piece of leather with some aluminum oxide or silicon carbide compound (these are usually 'white' and 'black', respectively) would work well as a field strop for stainless like AUS-8, after tuning up the edge on the stones. Green compound might also work, assuming the proper work is done on the stones first. It's a much finer grit (0.5 microns on average), so it doesn't do well if the edge isn't already pretty refined.
David
