- Jan 10, 2009
Hello,
I am going through the process of designing/modifying/building a few grinders, and was hoping to get insight into belt length/width and grit approaches.
I am interested in making flat ground kitchen knives, in stainless.
The longer the belt, the cheaper it is per inch and the cooler it runs, so if the space is available, and the manufacturer can get you what you want, longer seems to be the way to go. Assuming you dont need a narrow belt for contouring, etc., does the same hold true for wider say 3 wide belts?
I know some makers use a 50 to 400 grit sequence for a user, is this okay?
TIA
John
TIA
John
