Hey Guys...
Matt..
Thanks for the mention..
Still here,, however in the process of moving into a new house and new shop!OMG theres so much to be done...Anyway,, I'm still plugging away..
BGood..
ShWeet!
Now to answer some questions...
There are several ways to carry concealed..
For arguments sake,, I'll assume you mean IWB carry,,however won't rule out neck carry..
One of my favorite ways to carry is a static line,, either slipknotted around a belt loop or belt, then the sheath is tucked into the waist of the pants,,and a shirt keep it's from prying eyes..
Very comfortable way to carry,,which allows you to move it around,depending on the length of the static line... when the knife is drawn, the sheath comes out of the pants,(This is nice as it also protects you from being cut on the way out) then when the static line tightens up, the sheath pops off, leaving the knife "hopefully" in your hand..
This rig will also serve as a neck rig...
Another way to carry IWB is by using a G-clip.The knife tucks in your pants, and the front of the clip holds onto the belt. The only thing showing would be the front of the clip itself, which with dark clothing, wouldn't be easily picked up. On the draw,, this rig will stay put, however it will still allow for adjustments.
The bonus with this over static line carry,,is that it can easily be removed and tucked away without too much fuss.. The static line would have to be untied.
Metal boot clips are also an option in some cases,, however i've found that the force needed to remove a knife from a synthetic sheath is greater than the holding force of most clips other than a very select few which I've tried..
IWB loops made from rubberized material or nylon webbing also work,, however, don't serve much purpose,,as they tend to give slightly on the draw,and can actually hamper a quick draw,,by possibly twisting the knife in the sheath...
You either want a sheath that stays in place on the draw,, or one that completely comes out of the pants.. Partial movement of the sheath on draw can cause problems with some sheaths...
Not all sheaths are up to the task of concealments,,as they are usually either too wide, bulky or flimsy, or have straps,snaps and buckles that get in the way and make for an uncomfortable carry...However,, this is not always the case... A sheath designed to do this task would be a much better option in my opinion..
Please feel free to drop me a note if you have any questions,, I'd be willing to answer any questions you may have.
ericn@mnsi.net
ttyle
Eric....
