Osage orange as handle material ?
I have a friend who has been contracted to remove an Osage Orange tree from a heritage property here in south-western Ont.
Can any-one tell me if it is any good for handle/slab use?
If so how should it be cut, stored and worked ?
Thanks in advance.
Jim Ziegler aka kraut
I have used and still use at times the Bois D'Arc wood. After cutting, if you can get it sawed at a mill, do it. Get the bark off as soon as posible because there is a black and yellow bug that will bore through the bark and a white worm will eat the wood and leave 1/4" holes in it. I keep mine in a "hot box" (box with a light bulb on) and after a few months, it should be dry enough to use. Cut the wood so that the grain is flat with the scales so that when you finish it, the grain will look like the Pakkawood grain, in layers. This will keep the wood from splitting when you drill and peen the pins. I like to shape the handles and then replace the pins with ones that are 1/8" longer so they will stick out about a 1/16" to be peened. If you round off the pins a little before you put them in, they peen better. After peening, sand them off down to the wood and treat the handles with linseed oil or what ever your choice is.
The wood will turn to a nice brown after a period of time. Fresh, it is a yellowish color. I also like the small limbs (small grain size) for small knives and the larger grain for the bigger knives.
Ray Kirk
http://www.tah-usa.net/raker
This stuff is also called "Hedge", and makes a good, solid and tough handle. Not particularly attractive and well figured, but a good and durable handle material. I would have no problem using it for a machete or chopping type knife.
Danbo, soul brother of Rambo
Thanks for the info guys, this sounds interesting as I have found out via the web that this was the wood of choice for making bows by natives in N.A.
thanks Jim
