OT:Help sought for spyware removal......
Hello Computer People,:D
I consider myself about a 2 or 3 on a 10 scale when it comes to the world of computers. I'm learning alot concerning spyware, recently, but am having fits with something called "CoolWWWSearch":barf: . Anybody out there know of freeware or shareware that will remove it??? :confused: Don't want to spend $40 on this thing if I can avoid it.
I'm going to get some sleep now and will check back later this afternoon.:yawn:
Thanks loads!:)
Larry S.:cool:
Thanks loads!:)
Larry S.:cool:
Free and one from best - Ad-Aware SE Personal Edition 1.05 : http://www.download.com/3000-2144-10045910.html
and CoolWWWSearch removing tool you have here :
http://www.spysweeper.com/remove-coolwebsearch.html
I have Adaware, CWShredder, and Spywareblocker on my computer, yet EVERY SINGLE DAY I have the same stuff show up on my computer when I run the Adaware. Every single day, my homepage gets changed to aboutblank, even though the CWShredder says it's not on my computer. Last night, I ran Spybot Search and Destroy first, and it said my computer was completely clean. I immediately ran the Adaware, and it found 46 items like coolwebsearch and other malware. ?????
Ad Aware and Spybot both do better at some things than others. Make sure you have the latest version of both, run the "update" feature before you scan every time, and you're more or less okay, as long as you don't click on "DO YOU WANT 1000 SMILEYS??!?" and similar garbage that pops up.
Larry, for Cool Web Search, you need "CWS Shredder"
The latest version of Search and Destroy is 1.3.
If you update the 1.2, it will tell you that you have all of the updates.
Cool Web drove me insane until I found CWShredder. If this doesn't fix your homepage then you have something else hiding in your system. Maybe something that installs on start up ?
It amazes me that people who are smart enought to write this stuff aren't doing more with their talents.
Good luck.
Alex
If you have recurring problems with any spyware, even after running Spybot, AdAware, and CWShredde don't give up hope yet!
1) Make sure all of these are updated to the latest versions, and that you have all updates. (FYI CWShreder is 1.59.1, Spybot is 1.3, Adaware 6.181)
2) Try running all scans in safe mode. It is possible that some of the things being found can't be remved because they are being used.
3) Turn off system restore, and then delete the file (it will be hidden) that holds old system restore points. Nasties can and do hide there. Reboot, and turn system restore back on, and make sure to create a restore point.
4) Another useful utility is Hijack This!, you need to be careful as many of the things it finds are actually needed.
Larry,
I suggest you follow all of the advice given here. Adaware. Spybot, CW Shredder are excellent at removing hijacks and ad/spyware. I would also suggest that you download and run HijackThis, save the log and send me the file to check for possible bad programs ( I have done this for several forum members in the past with excellent results). Also, if you feel like shelling out $29 get yourself Webroots Spy Sweepr An excellent program that works well. Also download the free version of Spyware Blaster. What this does is prevent spy/ad ware getting onto your PC to begin with and locks your homepage. I have used this program for 6 months without any porblems and I find a lot lessspy/ad ware on my PC when I run the other sweepers. Fell free to email with any questions. :D
PS: Running these programs in Safe Mode is an excellent way to remove the junk.
Thanks to all who answered....I'm very pleased and will digest/compare the info offered and post the results, Again, thanks!:cool:
Larry S.:D
Here's what I use and I never get pop ups or spyware.
Mozilla: Web browser fairly powerful stops pop-ups and the sort.
Mozilla Browser: Mozilla.org
Mozilla FireFox: FireFox.com
ZoneLab's ZoneAlarm Suite: It offers Anti-Virus protection and is a very powerful Firewall. By far the best i've used. Automatic updates and does everything without be prompted or taking to much time. The actual software runs in the background so you hardly notice it. You don't get the pop-ups that McAfee has or the problems that come with Norton.
ZoneLab's ZoneAlarm Security Suite: ZoneLabs.com
If none of the above works, its time to take the next step.
Adaware and Spybot are scanners. They fix what is broke by researching all the crap on the net (they cover mIRC trojans, keyloggers, backdoor programs etc. as well as the mess you pick up off the web), building a signiture file (sometimes referred to as a reference file, hash etc.) and looking for the obvious signs and fixing them automatically.
The first possibility is that you're not using them properly and having found all the spyware/malware/crapware, you haven't actually removed it. In Adaware (I haven't found the need to use Spybot S&D), make sure you check ALL the boxes after the scan is complete to remove all the files.
If that doesn't work then we start having to do things manually :)
We start by killing all the spyware thats currently running. Download process explorer:
http://www.sysinternals.com/ntw2k/freeware/procexp.shtml
This free program is an extended version of the task list you get when you press ctrl + alt + delete. I use it because it shows ALL programs (some are designed to hide from the normal task list) and importantly, where they are installed. Make a note of the location of all suspicious processes and kill them. There might not BE any suspicious programs showing up because spyware these days (especially toolbars) tend to piggy back in on Internet Explorer but lets take things one step at a time.
In fact, lets take care of Internet Explorer now. There are 2 tools that make the inexperienced user's life easier. The first is BHODemon. Download it here:
http://www.definitivesolutions.com/
Basically BHOs or "Browser Helper Objects" i.e. toolbars are extentions/plugins for Internet Explorer that can do just about anything, good and bad. BHODemon checks your installed BHOs and lets you disable any suspicious looking ones with a click. No digging around in the registry :)
The other tool of note is HijackThis! (http://www.majorgeeks.com/download3155.html) which lists all the registry entries that Might have something suspicious in them and all running processes. Use this to get a list of possible trouble makers and post the log on the forum if you're still having trouble after this post.
Now we're going to check all the programs that run on startup to make sure you aren't just starting up malware programs every time you boot up. Microsoft have provided the tool for this with windows. Click "Start". "Run" and type "msconfig" (without the ") and click "Ok". Now click on the startup tab on the far right and uncheck anything that shouldn't be running on startup. If you don't know what it is, check with google. This applies with any of the steps :)
Now go reboot and see if you still have problems, then go round deleting all those files that have been giving you grief.
Finally you need to protect your computer against further problems. First you need a firewall other than the one provided by XP. There's a nice site with them all reviewed and guides on usage here:
http://www.firewallguide.com/software.htm
Once you've got that set up, make sure you disable XP's default one because it tends to create conflicts between other firewalls and programs.
The next port of call is of course microsoft for a round of critical updates to fix all the latest holes. http://windowsupdate.microsoft.com/
You need to check this every month or so.
Lastly, you may have noticed that most problems stem from Internet Explorer. Two things you can do. One is to install a code filter like proxomitron http://www.proxomitron.info. This basically acts as your own personal censor. Don't want any blockups? It'll strip the code out before it reaches your browser. Don't want to see pictures of a certain size (like advert banners) or files from certain servers to download? You can block it. The other thing you can do is use a different browser. The current recommendations are:
http://www.mozilla.org/products/firefox/
http://www.opera.com/
Hopefully, this horribly long post solves your problems. Otherwise let post a hijackthis! log and let us know what your problem is.
