OT: sossun patta
For all you sword lovers...this is the same sossun patta pictured in Rawson's fine book. The scabbard is as remarkable as the sword with an involved hinged plate that covers part of the open back that assists in getting the blade out. The gold filigree and metal work is quite remarkable.
I don;t know the actual Indian term for it, But in Western MAs we call it the "cheater knob." The use of this nifty gizmo is three fold:
1 - Allows the other hand space to grip it, much like the extended hilts on european hand-and-a-half swords. The two handed blow or strong block can then be executed with more strength than the one handed blow/block.
2 - Allows the defender to block lower blows, such as those to the leg. Usually in swordfights, the leg is a prime diabling target, and one must crouch low to guard the leg. However, the protrusion allows the defender (while holding the sword relatively vertically) to simply drop the sword's position a bit to pick up an incoming leg shot on the protrusion. The spike-like pommel protrusions on swords of this type almost always are bent at a curve away from the body to accomodate this block (a straight bar would be more likely to snag on ones pants or harness, or you wouuld have to hould the blade tileted back more to accomodate for this)
3 - Allows the attacker to lock up weapons or snare limbs, armor, or shields when in very close quarters (The big quillons you see on european swords were intended to be used this way as well).
If you come upon an opponent with a shield, you can get in close, slip the protrusion over the top edge of the shield (executed by punching forward with the sword, and letting the tip fall back along the arm parallel to the arm, thus thrusting the pommel forward). Then, near the end of the forward momentum, you snap the wrist forward to bring the sword tip up in an arc aimong at the head or shoulder (as this is executing, the pommel protrusion is snapping down over the shield rim, and the weight and momentum of the sword blade coming forward forces the shield down and out of the defnse abruptly, opening the ehad for the blow already on its way.
You could use the same maneuver to snare, a weapon, wrist, arm, or leg. handy fer getinng the leverage game in a locked up encounter, when the weapons and limbs are more viable targets for snares.
Another thing it might be useful as is a buttspike, where you'd use the same punchinng or hammer strike to say crack a nut with the butt of a knife. Instead of impact, this thing would pierce.
Usually, that gizmo is just a continuation of the sword tang, sometimes wrapped with wire, leather, cord, or other adornments that might give some grip.
Keith
I'm gonna have to disagree with Ferrous. The sword obviously has a built in AM/FM radio. :p
I am not any type authority on these swords, but know it is referred to as a "spike" and is typical of these khanda grips. As far as I know it only gets FM and on clear days UHF signals.
Here are some more examples.
and I thought that the thingy was an antenna for RF, so you could have a radio-controlled dancing sword!
Seriously, though. The spike would not be included on munitions grade weapons if there wasn't a practical use fer it. I'm pretty sure the "cheater knob" also appears regularly on Scottish basket hilt claymores, and other sword sfrom the period.
Here is a European style sword with the "cheater knob"
Scottish basket hilt with knob:
The knob is called the 'button' on clays.
The spike at the end is there to permit a two handed grip.
n2s
always chiming in with the short and easy answer.;)
I still stand by my other answers, insomuch as I have sparred with basket hilted longswords with such a device & used it for the previously mentioned techniques, albeit with mixed success...
How's "My three suns" treatin you these days, N2S? I noted he does not appear on your sale page, leading me to assume you and he are still in good standing with one another.
Keith
that this image is my new desktop wallpaper. Me likey.
I have a spanish bowie-sized knife with the same sort of profile, not a nicely executed tho, and certainly not so opulent a piece.
Keith
I cannot control the images I've been posting, but trust all of you NOT to use these images for anything. Not only did I sign disclaimers with the museums, but I gave them my word. I would hate to jeopardize these relationships.
Thanks for the tip, JP. I was unsinng it for my own personal use, nothing else, but removed it from the desktop to honor any standing deals.
N2S, lemme know if 3 suns ever comes up fer grabs. I would like dibs on it, basically, if a sale condition occurs. You are the right guy fer it, tho, so I doubt that it will go looking fer a home. I have my digi pix to remind me...
