Originally posted by jim_l_clifton
Brian,
Go to straightrazorplace.com they should be able to help you!
Jim
Originally posted by Pappy
I have used welding rod quite a bit. First I measure the hole, the rods come in a lot of different sizes. If nothing fits perfect I take the next size larger and carefully file and sand it to fit. I put a slight bevel to the outside of the scales to peen the pins so they will not move. I like using the welding rods because they seem to be pretty strong so, will wear less if they are used where there is any movement. They work for me.![]()
