Well, firstly, you may remember that I posted this request for a cigar tube, last week:
http://www.bladeforums.com/forums/showthread.php?t=354957
And, if you read the thread, you will see that Bryan (KnifeAddictAK) offered to send me some cigar tubes.
I've now receieved the cigar tubes, so I'm writing a follow-up, and a thank-you to Bryan. Also, there was some discussion in the previous thread as to whether the cigar tubes would be airtight, as I needed. So, I'm letting you guys know that these Ci-Guard cigar tubes that Bryan sent me are absolutely airtight, very rigid, and far beyond my expectations in every way.
RULE #1: Pictures are always required.
RULE #2: See rule #1
Mike, Mike, Mike, you know better....
Pics man.
Sorry, guys, but I'm not going to waste server space on pictures that will just look like a plain black tube. I'll give you a description, though:
They're made of sturdy black plastic; they're about 8 inches by 3/4 inch, the cap is about 1 inch diameter by 2 inches long, and is ribbed for a better grip.
If you still want to see a picture, here's a picture I took last week:
Will this fit into the sheath pouch on your INFI??
I found that the cheaper A&C (Antony & Cleopatra) tubes are a tougher, sturdier plastic, but the cap didn't seal well, and required a secondary sealant.
Have you found one that seals well??
I can't imagine any cigar tube would fit in the pouch that comes on a Busse sheath. Those pouches barely hold an Altoids tin. But I carry my INFI in my camera pack, and these cigar tubes will fit on my camera pack with no trouble.
They are quite rigid. I just now tested this by stepping on one, balancing on it with my full weight with both feet. It held tight and was not damaged in any way.
The caps seal very well. You must pull with an estimated ~15 pounds force to pull the cap off, and it pulls off with a satisfying "pop" sound. I would guess that they are waterproof to at least 20 feet.
--Mike
