Cliff's notes in the beginning because I can be long-winded: Can someone explain the pros and cons of using BLO to preserve and treat a couple of ~35yo 2x4's on a workbench?
My parents are downsizing and just sold their home. As part of this process I inherited a lot of stuff, including my father's workbench. Its nothing more than a 4x8 sheet of plywood supported by a 2x4 frame and pressure treated 4x4 legs. He used it as a general workbench however I'm into cars, motorcycles --well pretty much anything that burns petrol (like putting a 4.5hp engine in a 3hp snowblower and then running it on 110 low-lead AVGAS). As such, I will frequently be putting much more weight on the table than its ever seen in the last ~35 years.
I bought some 8' 2x6'es and plan on reinforcing the outer frame and supports with them which I think will both support more weight and prevent/correct the bowing or sagging in the middle of the table. As I was taking the table apart to move it I noticed two things, first, that each of the four kids have carved our names/initials in the 2x4's in a few places --or my brother who loves fire used a blowtorch to write his name in a few places
. Sappy & sentimental yes, but the dings, cuts and holes also bring back memories of all the Pinewood Derby cars & projects we did with dad over the years. Second thing I noticed was all of the indents on the bottom of the front 2x4 from using C-clamps to secure things to the table.
My thought now for the front & outer perimeter of the table is to keep the original 2x4 frame as-is, and then add the 2x6 reinforcements just behind them, meaning the front & rear are currently 8' 2x4's and the left & right sides are 44" long 2x4's. I'll keep that frame exactly as-is and cut a (doing math in my head) ~92" long 2x6 for the front & rear boards and ~40" long 2x6'es for the left & right sides, with 45-degree angles so I'll make a 2x6 box that slides directly inside the 2x4's... bolt the 2x4's to the 2x6'es and build/put it back together from there. This gives me the original 2x4's on the outside with all of the sentimental stuff and makes the table much more functional. Using C-clamps on a 2x6 the long way with 3/4" plywood on top of it can problematic unless you have giant clamps.
There is years of grease, gasoline, oil, oil & latex based paints, mineral spirits, turpentine, acetone, epoxy & resins and pretty much anything else you could imagine dried onto or soaked into this thing. Also, the wood has spent about 35 years in a basement next to a dehumidifier.
Would putting BLO on the outer 2x4's as a preservative be good/bad? Smart/stupid? Would it create a fire hazard any more than anything else (like using ether, acetone, 110 low-lead fuel, etc), or would the BLO potentially react with anything on there? When/if it ever dries would the BLO harden the wood like a hickory haft or would it possibly soften the pine sap and I'll end up with a sticky mess?
Thanks for reading/replying. Couldn't find another online forum/resource to ask and some of you guys seem to be linseed oil experts.
