- Feb 7, 2014
After the first cleaning of my large 21 I noticed that when I tighten down the pivot I can actually tighten it to much making the blade very hard to open. I was not cranking down on it either. I was under the impression that the pivot bushing is supposed to eliminate the possibility of that. This was after a cleaning and I had went into its first cleaning knowing I wanted to keep the washers in order of which side faces the blade and assemble them in the same manner. I ended up mixing up which side was in contact with the blade as well as which way the pivot bushing went in. Just as a side note I noticed the pivot bushing having a different finish on both sides. One was flat and the other more rounded. Anyways, when I reassembled the knife I played around with washer and bushing combinations until I found it to be as smooth as possible. I can still over tighten the blade though. I have heard some can come with the washers slightly thicker than they need to be which causes this. Any input on this would be appreciated. Thanks everyone.
