Overheated 80crV2
I put a couple 80crV2 knives, and a few cpm154 knives in the oven. With the intent to pull the 80crV2 out when it reaches temp.
Unfortunately I stepped away from the oven, and came back to find all the knives soaking at 1950.
Is the 80crV2 ruined??
Once they cooled to around 1400 I let them slowly cool down.
You will need to cycle them down to get the grain reduced.
Try this -1700°F and air cool to black,
1600° and air cool to black,
1500° and Quench,
1450°Quench,
then a 1250° soak for an hour and air cool.
The 1250° soak is to anneal it. You will have to give it a sanding to remove the surface decarb before a new HT. Do the HT as normal once the blade is refurbished.
The decarb is already there from the earlier over-temp and time soak, so itis too late to prevent it.
Yeah. Good point.
On that topic. I put some a2 in my kiln at a very high temp (i was going to try some thermal cycling, for a certain reason thats pretty off topic for this thread though).
And i forgot to put antiscale on it. It needed to sit for 30 minutes if i remember. Half way into the soak i remembered, and decided to just go ahead and let it finish, and deal with whatever comes out.
When i took it out, i had never seen so much scale, or scale quite like what occured. Im guessing because of the chromium it was a very shiny silvery scale, and i lost an insane amount of material, i didnt trust that what was left was even useable anymore so i threw it away.
